First time boat owner coming from several years of kayak fishing. I finally convinced the wife to sign my permission slip on a small boat. I found a great deal on a small 1648 Jon Boat. A friend gave me his 1992 Mercury 25hp that was used on a Gheenoe but later swapped for a 9.9hp. When he stored the outboard he ran the motor with the fuel line disconnected until dry.
This week I finally was able to pick it up from him and mount it. After spending an hour trying to start it, I took it to my friends house the following day. My buddy and I were able to remove the carb and thoroughly clean it although it was not gummed up or any type of debris in the carb. We pulled the plugs, found a good spark but cleaned them and lightly sanded the electrodes anyhow. They appeared to be gapped properly and put off a bright blue spark when grounded to the block. There are two kill switches on this motor, one on the tiller handle and the other on the back of the outboard. The tiller handle was disconnected when I initially opened the cowling. We tried swapping from both kill switches to just one or the other. Still no dice. We also used a little starter fluid into the carb but would not crank.
Is there anything that I should check into?
