darlington_john
"My 90hp can run all day long
"My 90hp can run all day long < 5200rpm but once I run wide open for a minute or so, the overheat alarm goes off and the motor goes into safe mode and idles. I can run it back up to 5000rpm and it is all good.
Motor has 300 hours, only freshwater use, and I changed out the impeller last year and it has only run about 1.5hrs since then but I thought it was the impeller since there was less water coming out of the pee hole at WOT and I mean a lot less. Once I changed out the impeller, at WOT it seems to have a very good stream.
Any ideas??"
Any ideas??"
