I rebuilt the water pump on the new to me 9.9 stroke (SN 0CXXXX). It will hold pressure at 10PSI for about 3 hours or so but overnight it will be down to zero. I have sprayed what I can with soapy water but can see no bubbles.
I re-assembled the bottom gaskets etc with no gasket sealant or RTV as the shop manual didn't call for any. I did notice that when I took it apart there was some black RTV on the plastic block,
I replaced all gaskets and seals with a kit, so I'm pretty sure they're good.
Should I pull it apart and put some RTV or Merc Perfect Seal on the lower gasket? Or is this sealing up "good enough?" I'm not sure what the spec is for maintaining pressure timewise. When searching the web, I see all kinds of opinions on just how long the lower unit should be able to maintain 10 PSI. 5 minutes to 24 hours!
Thanks!
Thanks!
