I was having all kinds of issues with the motor, but have since had a buddy with at least some decent know-how go through it. He rebuilt the carb (again), replaced the impeller, fixed the cam roller and pull start spring. The engine starts nicely and idles nicely, finally. In neutral, it'll throttle up 100% with no issue. In gear, it'll accelerate nicely to a low-mid speed but when it's cracked above "medium" it starts stumbling badly. Can't tell if it's missing, bogging, leaning out, etc.
I put up a quick video to maybe help hear the issue.
https://www.youtube.com/watch?v=saf6CGhVFX8
My buddy did say that to get the motor to idle, he had to turn out the mixture screw (the one circled in the pic below...that's not my carb but essentially the same layout) much more that he has on previous motors (like 7-8 turns instead of an expected ~2 turns).
Are there more adjustments to be made on this little carb other than the idle speed screws? what can cause this kind of throttle/load response?
Is there a reliable order of adjustment for the 3 setting screws?
thanks all!
thanks all!
