I have the same problem with the brass tubing off center. I dont think any gas can even get to the fuel bowl. Is it a good idea to be bending the small brass tube back to center? Is it even supposed to be in center, seems it should be.
Also with only pumping the fuel line, is that enough pressure to run gas through the carb? to make sure its freely flowing fuel
1. not sure, but my 8hp Mercury now runs
2. not sure again, but if the 3 mm brass tube in your Walbro WMC also was leaning against the edge of the 6 mm tube, maybe that's Walbro's design, which I've now altered(could you get Walbro's phone number and ask them?)
3. I think that pumping the fuel line only fills the carb bowl to the plastic float level, and that manifold pressure from the piston upstrokes draws fuel from the carb bowl, through the high speed jet, which is below the 3 mm brass tube in my Walbro WMC, to the crankcase,.
I can't remember how forcefully I bent the tube, or how well I centered it, but it wasn't perfect, and I remember the brass tube looking slightly 'bowed'.
The 8 hp Mercury started and ran twice last week in the 55 gallon drum but, each time, it didn't start on the 1st, 2nd, 3rd, 4th...maybe 5th or 6th...pulls...but finally started and ran.
I ran 2 carb bowls of fuel dry each time, and it started 1st pull every time(6 total, I think) when warm.
Pulling the choke knob 'full out', as the cowl text instructs, certainly forces a plastic lever down on the blue plunger of the Walbro's primer, and the throttle linkage moves forward when the 'full out' knob is rotated clockwise to start.
With the choke knob pushed all the way in, rotating the knob seems to have no effect on the throttle linkage, so I hope I got the 'worm drive' in the barrel end of the plastic shaft correctly engaged with the 'throttle moving plastic' inside that I can't see.
I have to keep experimenting with cold starts, because it starts tough only when cold. Next test, I plan to pump the blue primer, on the Walbro, by hand.
So far, I'm not sure that the 'fast idle' position has helped at all.
