OK, everything was solid and tight. I needed both tools to break the nut loose and to pop the flywheel. My home made tools worked easily and quickly. The key is solid and tight in the shaft keyway and it has a solid 3/32" of bite in the flywheel side. Throttle linkage was a bit stiff, so used a light oil to penetrate and loosen it up. Some slop in it, but it moves freely thru its range of travel.
On that - the tapered/shaped black plastic "cam" that pushes the roller to the carb linkage doesn't go all the way off the low end. There's a raised "arrow" sort of, a bit short of the end and that's as far as it goes on the roller. Hope I'm making sense on that.
While out there, I got an uneasy feeling, so dug out the multimeter and triple or quadruple checked the kill button and lanyard switch, JIC. Both are N.O. and close solidly when activated, so safe there, too. I'd've been mightily embarrassed if one of those was my whole problem.
