89 120hp looper v4 engine
drsmithtft
Motor runs good until you open it up and then it starts cutting out at full throttle. Any ideas? Any advice would be appreciated. Thanks DRS.
Use a timing light and determine if it is an ignition problem , one cylinder or all of them !!!------------trouble shooting is the way to go.------------------Just a new installation ??---------------Just changed the prop ???-----------Any change when you operate the manual fuel pump ??
