Manual says to
”Turn the twist grip to full open and to full closed positions. Check the clearance between the roller and end of cam slot. The roller should be approximately 1/4” away from both ends of slot.”
For the life of me I cannot accomplish this.
I “loosen jam nut and rotate thumb wheel to obtain correct adjustment” but if I get the WOT adjustment right then the fully closed position has the roller contacting the end of the slot.
Makes me wonder if the throttle cable is stretched or something.
Any thoughts?
Any thoughts?
