J
John Barnes
Guest
" I just rescently purchased t
" I just rescently purchased this engine. My problem started with fouled plugs. After insalling the proper plugs withe proper gap .040 (per Joe)I started and ran the motor briefly, then remived the plugs to inspect them at that point I noticed what appeared to be a vary slight bit of moisture on two of the plugs so I decided to pull the heads and take a look see, and there was a slight bit of water in three of the cylinders with sigs of leaky head gaskets, However my real concern is the amount of play in the pistons. at some point the motor has been boured to .030. If you move the pistons from side to side it seems to me that there is excessive play however moveing them in an up and down motion they seem to have less play. anyway I can push the piston all the way to one side and slide a .015 feeler guage down the side of the piston until it touches the top ring,with all the pistons are exactly the same. Is this too much clearance? before removing the heads all cylinders were running around 90 psi of compression consistantly, even with the leaky head gaskets. the other thing is that there is a scratch in one of the cylinders that appears to have been there for a long time maybe even the reason for the bour job and just didn't clean up. anyone have any advice for me??? I have ordered the service manuel but don't have it yet "
