I had a whole bunch of problems with this 150. Long story short I tore the whole motor down and put all new power head gaskets in. New carb kits and jets. New valves below the carbs (can't remember what there called) New coils, power packs and stator. New voltage regultor and also plugs. Everything is OEM except stator and power packs. Reed valves are better then what the manual says is acceptable. Compression is good. Runs great at anything over idle. Seems to idle good but take off stumbles alittle. Sometimes it stumbles just for a second or two and planes right out. sometimes it will stumble for 4 to 6 sec and takes right off. It's weird but runs great at mid and top end. I know your gonna ask so I'll tell you. I've been through these carbs a total of 5 times. Every hole is spotless. jets are new. carb floats are set to level when held up side down and 7/8 drop when turned over. VRO has been removed and 2 pumps installed. All new fuel lines. New primer bulb. I'm not completly certain but I think the link n sync is right. Starts good, runs good but just that darn take off. Running QL16V plugs. Was told to try have the timing advance a couple degrees before the throttle plates start to open. That did nothing and is why I'm thinking fuel. Out of ideas.
