Have a cracked lower unit on a 1989 85hp Force. Motor wouldn't shift out of forward. I have found a 1988 Force 125, can I swap the lower units? Should that fix the shifting problem? Also when i read about replacing the water pump it said I need a special tool to install the seal. If that true? I have changed pumps on small motors but never one this big. Thank you.
