D
Dave Spoula
Guest
"Open to all. I'm lost on
"Open to all. I'm lost on this and need some help. Although I'm pretty good with Chrysler RB engines (440/383 cu automotive), I'm now at a loss on my 1984 Chrysler 90 HP, 4 cyl. outboard.
First, so you know what we're working with here .....
1984 Chrysler (Star) 90 HP 4 cylinder
Model # 906S4A (nine-zero-six-ess-four-a)
Serial #1036 (one-zero-three-six)
Operating Range 4250 - 5250
BIA HP 90 at 4750
I believe the ignition system is the "Prestolite Magnapower III" (Type III Ignition System per Seloc Chrysler Outboard Repair Manual 1962-1984, copyright 1988, page A-52 in the Appendix). I also believe this is referred to as the "Alternator/CD" ignition.
I am troubleshooting based on the above named Seloc Repair Manual.
I am limited to an Analog VOM for testing purposes.
Symptoms .....
Engine will not start.
Ignition switch checks fine. Also tried a replacement with no improvement.
I have spark on only cyl. #3. The spark is good.
Swapping the other 3 coils into the #3 position, all produce a good spark.
Swapping the CD units still produces spark on cyl. #3 only.
Stator windings visually from bottom side, ( I have not pulled flywheel as yet), appear to be OK and is producing voltage across the blue and yellow leads to the CD units.
The triggers indicate continuity and no shorts to ground.
I'm interested in direction for the correct Chrysler Service Manual, troubleshooting recommendations, parts recommendations and reputable suppliers.
Can you help me out here?
TIA,
Dave Spoula
[email protected]"
BIA HP 90 at 4750
Symptoms .....
TIA,
Dave Spoula
[email protected]"
