Qbanredneck
Hello all,
Recently had issues high speed, would not go over 4,000
redid carbs
compreesion 120 each cyl
new spark plugs/ cables/fuel lines/impeller
passes the spark plug test
my stator had low ohms for high speed
bought new cdi stator and new trigger since cables worn
I marked the flywheel with white nail polish so I can place it back in the same position as when I popped it off
took back to water and ran like crap still
i do have an inline filter-Oem but also have put a water separator right out of tank-
it starts and moves but does not want to pick up speed- probably no more than 2k rpm,
it does not sound like a 2stroke-sounds almost bogged down
the top two spark plus feel hotter than the lower two when touched incase that means anything
Im leaning towards removing water separator and rebuilding carbs, just wanted some advice from yall
thanks
redid carbs
thanks
