hi reading my book for breaking in the engine
I says during the first 10 min to operate the engine in gear at fast idle... but you cant lift that high idle lever in gear.. or put it in gear after you lift it up
so what do they mean
and I just going to test it in a test box I have with water to just get the engine running for 10 min to make sure it fires and then another day get it to the river..
and it also talks about first 50 min.. you start off to run it at 3500 rpm or below... do you keep it at 3500 rpm for that full 50min or say 1 hour nothing higher only to plane it but bring it right back down to 3500 or below right?
