Hi,
I've got a 9.9 that won't get out of forward. I've dropped the gearcase from the motor. I can get the shift rod to move up and down if I turn the driveshaft slowly, but the prop is always spinning, and in the same direction. I drained the gear lube, which was black, but no noticeable metal shavings. Do I need to fab up a bearing carrier puller and pull her apart? I'm willing to do it, just apprehensive and want to make sure that it is necessary.
Thanks,
Thom
Thanks,
Thom
