81 Merc 20 hp timing
seabob
Removed flywheel it is bolted to a 8 bolt hub on crankshaft how is it reinstalled does it need to be in a certain place for timing cannot find any marks on hub or flywheel thanks
It sure has to be put back exactly as it was.------It does control the timing !---------Look for matching rust / paint marks around the bolt holes to see if you can then put it back as it was.
Will try doing that seems like there should be marke or some other way thanks
