If you changed the ecm and the problem stayed with the engine and you cannot actuate the IAC with your scan tool....I would say you have a wiring harness issue. Problem is.... if the harness is bad.... there is no fixing it. You would replace it as a unit.We did that! Problem stays with same engine!
