stromzilla
"It continues to stumble, lous
"It continues to stumble, lousy idle, very difficult to start when cold, seems to run better when it gets above 2,000 rpm, sometimes stops dead in it's tracks (1,000 rpm to nothing in a fraction of a second). When attempting to start it sometimes takes hard hits shaking the boat. The carbs are clean as can be, compression is 120/120/125/130, coils and pwr. packs have been replaced, fuel pump has been rebuilt, plugs have been replaced, ignition switch has been verified for shorts and is good. Tonight I'm pulling the plugs to verify each has adequate spark when cranking. If the spark is good could someone point me in the next direction? I'm thinking of disassembling the intake reeds to have a look. Could a bad stator be causing my issue? I did notice a little bit of a dark substance under the flywheel. Please help before I lose my mind or the motor gets hauled to the dumpster."
