78 Evinrude Controller
krusty
"I have a 78 85 hp motor on a
"I have a 78 85 hp motor on a 78 Sylvan Deck Boat.
On the controller above the shift/speed arm is a
black raised center switch. Does anyone have a clue what this switch is for. It has no detents, it only turns like a thumb screw and is plastic."
"Larry, It sounds to me like t
"Larry, It sounds to me like the tension adjuster for the shift/throttle. Turned in it would tighten the tension on the shift/throttle. Brian"
"Larry, does it actualy wind i
"Larry, does it actualy wind in/out or are you just observing that, that's what it seems like?
It may also be a (release switch) to allow you to engage the throttle without actually putting it in gear - since it certainly doesn't sound like a trim button...
Hey, push it, twist it or turn it and see what happens
You probably are not going to hurt anything...."
"it does sound like the shift
"it does sound like the shift tensioner. It keeps your throttle in a specific position while cruising so that the throttle doesn't move. I would say, do whatever Graham says!! He's the man."
