Hello,
It has been a long time since I have posted on here mainly, I have left the industry due to winter lay off's up here in the norske. Any how now I am starting to get back into for side work considering some stuff my family has gone through. None the less, I appreciate any help that can be given.
Now to the story, I am currently working on a 1978 70hp Johnson, inline 3 cylinder, to put a long story short they were having starting issues. I went through the electrical and tested the solenoid along with rectifier for the not starting and inability to maintain a charge within the battery. After doing so I found out they were bad and replaced those along with the key switch. The reason the key switch was replaced is due to the key had broken inside and was not able to turn/engage correctly.
First off, I made the mistake of going with a sierra switch that seems to have one extra point on it that says I. The service manual and the origonal setup was having both the ground and kill switch on the M portion of the switch. I checked for spark while starting and there was none on any of the coils, I ended up removing the kill switch line off the power pack, after doing this it was able to start, however as we know it would shut off until i touched the wire back to the pack.
I am curious what I should do, I believe I have it hooked up correctly but am unsure, any tips on what should be done?
Thanks,
Jogin
Thanks,
Jogin
