bearclaw360
Hello fellow boaters! I have a '77 evinrude 25hp short shaft outboard that I hit a log with unfortunately. anyways upon inspection I noticed whoever had before me used a steel pin for "shear pin", which only bent. I replaced the lower housing which had cracked, sealed it, fluids etc. put a new prop on it, made sure it was shifting gears ok which it was, and then started it. it runs great, but the prop doesn't turn. I only ran it for a moment. I'm expecting it to have sheared something else off etc. but figured before I started tearing it apart I'd ask some pros. is there an upper shear point? or another likely place to start looking? is the drive shaft stripped perhaps? any help is much appreciated. Thank you!
