Been a while since I updated, but here's where I'm at now. The 23P prop worked great...I can cruise along at 37 mph and 5500 RPMs. Motor runs strong after I get it running. I've tweaked, adjusted and fiddled with nearly everything so far and am still not satisfied with where it is. The best I could get it to consistently idle is about 1000 RMPs but I have to start it with high throttle and let it run a bit and bring it down. After it's warmed up some it gets a little better in that I can usually start it in neutral at idle position and be ok. Shifting into gear is a little tricky from time to time. It wants to die when shifted into gear, I can give it a little more throttle and it will stay running. Today was the best its been since I bought it. I tweaked some stuff on the ramp before putting it in the water. I was able to start it and let it idle while I parked my vehicle. Got in and could low speed maneuver while shifting into/out of gear around the ramp. Pulled out and went full throttle, no hesitation at all and pretty quickly I was up to 5500 RPMs and 37 MPH. It ran great the whole run. Let out to idle into a cove and it behaved perfectly. I made several more stops, and each one the engine was very well behaved. Started right up, idled fine, shifted good, didn't die! Then I came back to the ramp...I pulled it up to neutral and tied off to the dock. Got my trailer backed in (boat was idling the whole time, maybe 2 minutes) and when I put it in reverse it died. I spent 10 minutes trying to keep it running enough to load the boat on the trailer. Finally ended up having to come in a lot hotter that I like to get it on there. I just can't figure out why it would do so good for 3 hours and then go to total crap all of a sudden. It was almost like it knew I was at the ramp! I've tried a couple of different procedures to link/sync. I've got new plugs, new plug wires, a new starter solenoid, new voltage rectifier (old one took a dump last weekend) and a new water pump (old one was only putting out 3-4 psi, new one is 5-6 not sure if that is enough or not). I ran all the old fuel out and refilled with non-ethanol gas and Amsoil premix oil. I haven't pulled the carbs yet, not sure I will. I haven't done much carb work before. I've checked around and can't find anyone within an hour of me that knows much about these older engines. I'm beginning to think I either need to expand my search area or try to find a reasonably priced used engine to trade on. I did have a though today, the control box looks to be older that the engine. I owned a 1988 Bass Tracker with a 75 HP Mariner 3 cyl and the controls were much different than these. Could they be causing some problems? The shifter seems to work OK but the cables look to be too long, not sure if that would matter or not.
