OK, day 2 with project engine, sprayed pre-mix into the carb, hit the switch, and it turned over and fired for a second. Not hooked up to a tank yet, need right hose connection, but anyway, tried to turn it over again, and the starter motor started grinding against the flywheel after a half rotation. removed spark plugs, and flywheel turned, put spark plugs back and flywheel got stuck after a 1/2 rotation. I can turn in manually with wrench.
Engine hasn't run in years, again this is a project, but any advice is appreciated.
