tnsailorguy
"Ok this is strange. Last spr
"Ok this is strange. Last spring I was left dead in the water. The problem turned out to be the bushing on the distributor had worn to the point the the teeth had worn on one side of the gear and boat stopped getting fire. We took the shaft from an auto 454 and machined a new bushing. Sunday the on a cruise the boat began to lose power would not come up on plane. It ran fine around 2 grand. The mechanic called today and said the bushing was worn again. Luckily I had already purcheased a replacement and he is in process of replacing. Two senerios 1 the first replacement was not put together proberly and it eventually gave out the seccond would be some other problem possible a warped camshaft. It is unually for the bushing to fail in the firt place so i am concerned I may have a larger problem. Any thouughts? How much is a replacement camshaft for a merc 7.4? I know the engine will have to be pulled if that is in fact the problem. In the fall I had cut the engine off a 1800k and had gotten backwash in the cylender, cleared water and ran fine til the first bushing went bad. related?"
