jcarpenter88
(Model #65ESL-72S)I am
(Model #65ESL-72S)I am having a problem with a miss at higher speeds and suspect the one of the coil arcing to ground. I have removed all three coils to test with the ohm meter and this is what i have found: when checking across the wire going to the power pack and the wire that would be grounded to the head they all three check showing made.Is this coorrect? when i check from each wire to the wire that would connect to the spark plug two show 2000 ohms and one shows 0. They show 2000 ohms no matter if you hook it to the wire that would be hooked to the power pack or the wire that would be hooked to ground. Can you tell if i have a bad coil?
