Hello everyone,
I have a 1977 Mercury Marine 700, 70hp two stroke that stalls as soon as it’s put into gear. Warm or cold it is the same. I have plenty of water at the tell tale. Carbs are clean. Fuel screen is clear. Plugs look fine and are Champion L76V. Compression is 140 psi on all three cylinders. It has about 4 psi of fuel pressure which holds after it stalls. I found one fuel hose dry rot cracked but not leaking and replaced it. I found the #2 cylinder plug wire high on resistance and replaced the set. I’ve replaced the primer bulb and hose. The tank vent seems fine and I’ve tried running it with the gas cap loose too. The fuel is fresh, without ethanol and mixed 50/1 with Pennzoil Marine Premium Plus. The bulb stays hard. It restarts easily, but as soon as you put it in gear it stalls. It idles smoothly in neutral around 1,000 RPM.
I’m at my wits end. It will idle all day in neutral. Throttle response with the warm up lever is good. It will run in gear on land with the ears attached, but as soon as it’s in the water it stalls. Any help I can get is greatly appreciated!
