"Yes I feel like a A-1 complet
"Yes I feel like a A-1 complete idiot. Bought two new tanks to replace old rusted one. Engine running great on fuel tank #1 with 50:1 oil mix. Switched to fuel tank#2 that contained only unleaded fuel. I had forgot to add the 2 cycle oil. Engine ran at near full power for about 10 minutes then stopped. I realized I had also forgot to open vent in tank #2. Opened vent, primed bulb and engine started. Ran for another couple minutes then stopped. I realized my error with no oil in fuel and switched back to tank #1 with oil. Ran for a couple minutes then stopped and wouldn't restart. Started for a fresh water engine flush 1.5 hours later but sounded a bit funny. Did a compression check on cold engine later in the day. Top cylinder was 30psi with other two at 120psi. Added some 2 stroke oil to top cylinder and checked compression again; it went up to 40psi. I know I need to take apart the heads. I will have to buy a manual to do that or pay a shop $200-300 to do it. The shop guesses $3500-4000 for an overhaul. I can't afford that amount. I have time to work on it. Have been ok mechanically in past. Can't afford rebuilt motor at $5500 or new at $8000. Thinking of selling boat as is. Any kind suggestions?"
