fredbriggs
Have had this problem ever since motor came out of shop after complete overhaul. Engine will not idle in gear. Have sync all carbs with ball gauge, linkage adjustment to cam adjusted. Timing set at 4 deg, ATDC, but idle only around 400 rpm and when put into gear chugs and dies every time. Manual says that if all adj orrect and you want to increase idle speed to decrease timing. Well if I unhook the cam linkage and unhook the throttle cable Start engine and with a timing light hooked up engine needs to be around 10-12 ATDC and has good idle and smooth running. Not sure if I have enough adjustment in screw to achieve this much timing? Only other thing that has been done is the VRO stopped pumping oil so some one just plugged the oil line to pump and is still allowing pump to pump fuel only. Also dont know if this is any thing or not, I can not keep the fuel bulb hard while running. Dont know if this is separate problem or actually has something to do with the idle problem I am having. Oh one more thing if I trim motor all way up engine rpm increases by 2-300rpm, if I lower all way down engine will actually die after a couple of min. Some thing to do with back pressure in exhaust??
Any help to steer me in the right direction would be appreciated.
PS Engine is a 1996 J70TLEC
Fred
Fred
