I have a strange problem with my 1963 Evinrude 40 HP (Model 40363-DA converted to mechanical shift). It starts and runs beautifully at all speeds from dead slow to WOT. The problem is that, after 20 minutes or so it suddenly dies. It doesn't seem to matter what speed I'm running the result is the same. When I turn the key it restarts immediately with no effort and returns to normal operation for another 20 minutes or sometimes much longer and then dies again. The carb, choke and fuel pump have all been rebuilt in the past year and I have all new fuel lines, new fuel filter and a new gas tank. There is no over-heating and I'm getting great spark. Cylinder compression is 120 and 118. I have changed the needle valve and seat even though I already had a new one in the carb and the float level appears to be exactly where it should be. As I said, this one is a head scratcher.
If anyone has any ideas I would appreciate hearing them.
