First timer here, I have a 1959 Johnson Seahorse 35 HP.It starts fine, idles fine, goes into gear fine, and pulls fine at low RPM. The problem is when I increase the throttle it's like someone pushes in a clutch. The rpm just starts getting higher and the prop stops spinning, all the while the levers remain in gear, but it's not "in gear".then I slow the throttle way down then it kicks into gear.No matter how slow I try to increase the speed it does the same thing. I don't know much about outboard motors but I'm willing to jump in and try anything.Any help would be appreciated. Troy in Wa.
