Hi everyone,
I have a 1958 Evinrude Lark 35hp that I have been working on for a while now. last year I was able to get it running though not very well. So, this year I have been really trying to get it going well.
the problem: The motor will start and run for about 20 minutes then it will slow and shut off. It won't go full speed, it only seems to want to get up to about half speed. It idles in neutral but you have to hold the throttle all the way forward to the stop point in the neutral position. When you go below that point to shift you have to do it quickly or it will cut out.
What I have done so far:
I set the timing using the special tools, so I'm pretty confident that is good.
I cleaned and rebuilt the magneto.
I have good spark and the plugs look good as well.
I just replaced the gas and oil with non-ethanol gas mixed 1/2 pint oil to 1 gallon gas as suggested in the manual, this seems like a lot to me but doubt this is the problem
I'm over 100Psi on both cylinders for compression
I have checked all the wiring and the fuel lines
This is where I think the problem is most likely:
I cleaned and rebuilt the carb most recently. I was adjusting the level on the float height and in the manual it says, while holding the carb upside down to make the float even with the mating surface of the bowl. I'm wondering if this might have set the float too high and is flooding the engine.
the other thing I have done recently is to adjust the "throttle cam timing" I might be wrong on the name of that but it's the set screw on the linkage that controls the shutter valve as you engage the throttle. The manual was a little vague on how this is done but I think I got it close.
If you know what could be causing my problem or know what I should be checking next please let me know.
Thank you
Thank you
