"Raw water cooled GM 350/280 d
"Raw water cooled GM 350/280 drive. Under a load, the temp runs about 190 at idle, and 200-220 at 3500-4500 rpm. When I shut the engine down, Its hot enough that the battery cant turn the starter over until a 30-45 min cool down, after which it fires right up (compression?). This tells me that the engine is pretty hot, as the guage will peg when I shut the engine off.
I have replaced the manifolds and risers, raw water pump, recirc pump, thermostat, temp guage, sending unit and also changed the gasket on the drive water neck. Batteries, starter, carb and alt are all brand new, along with all electrical connections, batt switch and battery cables.
The problem is, when the boat is on the trailer and the drive is submerged in a tub of water, the flow is strong. I disconnected the hose to the recirc pump and the flow is good and increases with rpm. I did a pressure test from the raw water pump back to the drive by taping up the drive inlet vents and that checked out good. I also pulled the heads, changed the head gaskets (they were in good shape) and replaced all the freeze plugs after flushing out the block (lots of sand/silt).
I am running out of options and was hoping someone had a few nuggets of wisdom to get me on the water.
Thanks in advance."
Thanks in advance."
