57 L Marine Engine
"Head gasket material, cam, st
"Head gasket material, cam, starter, carb, fuel pump, distributor, material of the freeze out plugs, material of the coolant circulating pump, thermostat housing....."
Yes I did a little research an
Yes I did a little research and discovered a big difference.
I am looking to increase my horsepower...I am running an AQ225D (5.0 L)What are my options?
"Quote: [b]What are my options
"Quote: What are my options?
If you want a true marine SBC, don't do the dished pistons. Build one using a "quench effect" style piston and the appropriate cylinder head combustion chamber size that will give you a correct C/R.
This can be done with one of several Q/E pistons and with several cylinder head selections.
The rest is using a marine cam profile and many of the above mentioned.
If you go with a closed cooling system, you do not need the marine Circ Pump nor the marine head gasket set.... and can save a few dollars.
I do not know which boat this is regarding, but IMO, your best all around "bang-for-the-buck" is the addition of a Duo Prop (depending on the hull)."
