Good morning everyone,
I recently converted my 2003 Johnson 50 HP from the VRO to conventional fuel pump. I had no power on plane with the VRO and decided it was time to swap over to the conventional and change the plugs at the same time.
I purchased the SIERRA #438556, removed the pulse port bolt on he side of cylinder 1 plugged everything in and capped off the VRO pulse line. The engine has trouble starting and will not stay on.
Since everything ran fine 24 hours before I didn’t believe it was the carbs but looked them over anyways. The carbs are very clean, and there’s brand new spark plugs in the engine. Gas lines and primer bulb are also all brand new I swapped them out while changing the fuel pump.
I’ve looked over everything. The engine will start for about 10 seconds like a rabid animal and die out.
Has anyone else had this issue after converting?
