First, check all your wire connections very thoroughly,especially main grounds and the like. How long are your main battery leads from battery to starter lug and what gauge are they? How did you set your timing? You need to use a timing light. No way you can do it by ear. You probably already know this but figured I would mention it. It takes quite a bit of amperage to turn over a 470 with the delco starter. By the way, the originals are better than the replacement afermarket starters if rebuilt properly. Do you still have the factory water cooled voltage regulator? If so, get rid of all that nonsense along with the rectifier (generator inside front harmonic balancer). Buy an aftermarket alternator kit of some sort. Are you sure your key switch is good and you are getting proper voltage to starter solenoid. Could be alot of things so I figured I would get you started with these first. I have a 1988 3.7lx 180hp that I have recently rebuilt with virtually every upgrade imaginable. Just cause the starter is new doesn't mean it works. I bought the aftermarket alternator kit and the alternator had to be repaired by a shop because it was defective. So, is the starter that you bought an Argo or something similar? My Delco starter turned the engine really slowly when I first got engine and I carefully took it apart cleaned everything up real good and it has been working properly since. all the best, Tom
