*** I assume from the above comment that your REV RH Rotation Engine camshaft is chain/sprocket driven..... (I.E., camshaft rotates RH just as the crankshaft does.)Ok, been battling reverse rotation eating distributors for way to long now, trying see if anybody knows of any old style gear to gear timing sets out there that we can get to work on a gen VI block, *** want to get rid of the reverse cut cam/dist gears.
Mark, that would be real trick to do!Mark said:Unless the timing cover has been removed, the reverse rotation (RH) standard production GM blocks use the same distributor for either rotation engines.... and I don't think you can get a reverse rotation distributor gear to mesh with the drive gear on a normal rotation camshaft....
Ayuh,..... Only the crankshaft turns backwards, the cam turns the same way it always does,.....
