"I'm pretty much done with
"I'm pretty much done with the port engine (exh manifolds, elbows, risers, fuel pump, coil, all new hoses, thermo, plugs, RWP).
Swinging around to do the same on the starboard side. On this engine (maybe I posted this a couple of months ago?), I discovered coolant under 2 of the intake manifold bolts when I removed the linkage bracket.
I didn't have any coolant loss or obvious signs that coolant was getting into the combustion chamber. I pulled all the plugs, they are running rich but none of them are steam cleaned.
I did a compression test (cold) yesterday and came up with 135, 140, 140, 149, 135, 140, 138, 137.
I'm assuming that I need a new intake manifold gasket which I can see was done before. I think this engine had a valve job at one point. I know it's not residual coolant from prior work because it will flow out if I remove the bolt when the engine is running.
I removed the same two bolts on the port engine and didn't see anything. You can see the coolant in the hole that's circled, there's also some (not as high) in the one next to it. I didn't remove any other bolts, just these two.
I'm not sure what the backside of that intake looks like and where coolant should/should not be.
Based on this picture, would you assume intake manifold gasket as well?
intake manifold
