Vanuatu Pete
I have inherited a 40 horse carburetted 4 stroke that visually appears in great condition but has a fault. Runs on 2 cylinders only runs at full revs. Merc dealer seems more interested in selling a new engine instead of fixing this one. So far ECU has been replaced as well as the coil assembly under the flywheel. Coils test fine as do HT leads and plugs. Connected to the green common wire on the coil circuit where it returns to the ECU there is a black wire that is grounded to the block. This wire appears as if it might contain a diode as it show open circuit to ground but about 4 meg ohms resistance from ground to the harness. Beats me what it is for but with it by-passed and grounded no spark and if completely disconnected the engine still runs on 2 but idles only and won't rev. Any ideas where to look before I start tearing down carburettors?
