leogallant
Hi guys,
Was out shrimping on Wednesday and I noticed the FishFinder went off about 1 hour into our trip. 20 minutes later I had turned of the motor and when I went to start it up, not enough juice in the battery.
After getting towed back by fellow shrimpers (whew!), I've been going through my mind what happened. First clue is the fish finder going out, as I've read they are the first to go when there's low voltage.
I've tried testing the stator and rectifier:
TESTING RECTIFIER(Evinrude part #
TESTING STATOR(Evinrude part #
Thanks!
Leo
0581778)
: I start up the motor (was able to recharge battery no problem - eliminating bad battery issues), I have the red wire from Rectifier detached from bus block. With multimeter set at 20V DC, I ground the black lead to engine, and put red lead on the red wire from rectifier. I only get a reading of .63 Volts DC and I'm guessing it should be reading at least 13 Volts DC, right? This tells me either the Rectifier is bad or the Stator is not supplying enough voltage and is bad.TESTING STATOR(Evinrude part #
0581252)
: I'm not quite sure how to test voltage. With engine running, I believe I'm supposed to get between 250 and 300 Volts AC from each of the 3 wires coming from stator? Where should black lead go and where should red lead go? There are 3 wires from the stator: yellow/blue stripe, yellow/white stripe, yellow. Also, having no luck testing resistance, set multimeter to 200 Ohms, and touch black lead on one wire with red on another until you've touch the combination of all 3 wires from stator, but I'm getting no reading...Thanks!
Leo
