"Charles,
A 13X19 would be cl
"Charles,
A 13X19 would be close to a direct replacement.
I did the math on your 13x19 at 5200 rpm with a 2:1 gearcase. With 10% slip you are still around 42 mph unless the prop is slipping a lot. If you're truly only at 35mph, I'd go down in pitch
A 17p would put you at 37mph @ 5200
a 15p would put you at 33mph @ 5200
Of course you're rpm's will change with the change in load. I don't know how big you're boat or motor is, but I'd think a 17 or a cupped 15 would best match the motor to the boat. Do you have experience with anything other than the composite 4 blade?"
