Hey everybody hope you all can help. I have a 1985 70 hp J70elcos that sat for two or three years. It is pretty clean. My problem is the third cylinder will not run. Compression is good I do not have a gauge but the intakes have good vacuum while engine is running. I have rebuilt the cab and paid special attention to the main jet and all the others but it was pretty clean. The float is properly adjusted also. I replaced a couple fuel lines. I am using a clean portable tank with a new line assembly. The plug is wet so it is getting fuel. The spark is very good and jumps a 7/16" plug tester gap I saw mentioned in the forum. Replaced plugs and wires. When the engine is running and I remove the plug wire on the cylinder there is no loss of rpms when I take the others off it dies. Please let me know what you think and thanks in advance to all the pros who share their experience and the amateurs like me who keep the pros in business.
