"I checked oil level ran boat
"I checked oil level ran boat for 1/2 hour, oil pressure drops from 50psi to 20 psi.engine running fine. Docked boat shut down engine checked oil level, no oil. Hauled boat changed oil filter and added 7 qts of oil. engine started right up but no oil pressure, shut engine down. Oil level is still full and by the way the oil loss I believe is contained in the drip pan under the engine. There is no telltale signs of the oil leaking ie oil cooler, filter, pump, etc. help, thanks bp"
