goatbuster
Just put in the new thermostat, salt water cooled. Hooked up fresh water hose to test run. I think I noticed droplets of water slinging from the bottom of the flywheel. It's just a small amount and wonder where it could be coming from. Could the pressure from the hose into the cooling water system be causing it. Is there a water passage that could have corroded through and spraying a mist inside the flywheel enclosure? Does anyone know how the water system runs through the 350Q and if it's possible to get a leak in there. Thanks
