bortSanders
serial: 2A191167
2014 SeaRay Sundancer 260
600 hours
Won't rev past about 3200 rpms. No alarms or any indication of problems on the gauges.
I caught up on past due maintenance in an attempt to fix the problem: correct plugs NGK 5599, OEM Cap Rotor Wires, Water separating Fuel filter
Batteries are new, clean tight connections
no change in performance since completing this work.
I did find a small chafed leak in the vacuum hose from the fuel pressure regulator (elec taped for now), but I figure that should be a low rpm prob not a high rpm prob.
prop was bent and has since been replaced, no change
any help is appreciated!
600 hours
