1973browning
"A friend of my brother in law
"A friend of my brother in law bought a brand new 350 mag crate motor for a 25 foot Grady White From Mercruiser. He said he spent $16000 for brand new engine system and drive. I guess that was for installation also. (I hope so for that kind of money!) Anyway, he said he has had an ongoing problem at 2200-2400 rpm. Apparently, the engine breaks up at the above rpm range and as soon as you go above or below the rpm range the motor seems to level out. He had a cerified Merc. mechanic work on the boat for quite some time without a bit of luck. Mercruiser keeps telling him from day 1 that he needed a new distributor cap. (What a load of dung!) The cap,rotor,wires and plugs have all been replaced and he still has the same problem. Mercruiser also stated that it could be the ecm but refused to pay for it from day one. Is it possible that he has something wrong with his distributor or coil? I did not know what to tell him so I decided to post for him hoping one of you guys might have an answer or lead him in the right direction. He has 400 hours on the motor presently so it has been going on for quite some time. It does it when the motor is cold and when it is hot but only at those approximate rpms. I guess he has alot of money buried into the thing and I did not want to mislead him into buying parts that he does't need! I do not know enough about the 350 mag motor to help him but figured I would ask you guys in the hopes of putting him in the right direction and possibly help him solve his problems. He was also told that it could be the ecm,distributor itself,or possibly the coil but I guess he doesn't want to keep dumping money in the wrong direction. Any help would be appreciated greatly, sincerely, Tom
P.S. Merry Christmas to all and God Bless!"
