Kyle Krist
it was running 3-4 yrs ago but not it just wont even try to start the starter just spins forever and theres no spark at all and no fuel going to the cylinders
That is the overheat and low oil alarm circuit. The fuel issue is likely the carb passages are plugged w/dried hardened varnish...it is going to take a good soak in carb cleaner and blowout w/compressed air. Rebuild the fuel pump while you are at it...it is likely needed,the wire is tan-blue
No...they have a fixed gap and the spark jumps from the center to the rim of the plug...what do they look like? This is the only plug you should use: MERC. PN 33-97180Q - NGK BUHW. A new set can't hurt.i have the center fir spark plugs were it ignights against the piston head
Leave the wire attached to the plug and ground the plug's case to the engine while cranking it. If you can't see the spark in the daylight you should hear it as a loud "snap" each time it fires. Get a spark gap tester and attach the plug wires to it while you crank it...you'll see the spark if it's good. Get some help from an engine knowledgeable friend.how do u tell if theres a spark on them
