prestonstark
"Low hour engine, used regular
"Low hour engine, used regularly with recent raw water pump problem. (This is dual impeller type with bypass from thermostat back to inlet piping)The following was done- replaced thermostat, flushed cooling lines/oil cooler, replaced hose (correct type) from thru hull fitting to inlet piping and hose from thermostat back to inlet piping (did find someone had put a "plug" in the line), flushed-checked thru hull fitting, flushed checked inlet piping. Finally removed the hoses from outlet side of pump and found it would only pump with inlet hose filled using garden hose. No suction. Found pump impellers to be fine.... Just installed a NEW Sherwood pump- same problem, no suction. I am stumped."
