Eric Johnson
[FONT="]Are there reverse rotation cams available? Is the rotation of the distributor backwards as well? The gear on the back of the cam that spins the intermediate shaft- is it cut in a reverse pattern or is it the same pattern as a regular small block?
Since I will be building motors I would love to be able to update both to magnums with the roller cam and need to know the answers to these questions to see if I can have a cam ground for my application.
I have build a lot of these small blocks and have even retrofitted an OBD1 magnum motor into an older vehicle. I think it would be cool to do the same with these boat motors. Has anyone tried this swap?
If I can't get the roller cam I want I will at least use some magnum style heads on the rebuilds to get a good quench motor.
[/FONT]
[/FONT]
