318 Big Time Blow by
Similar to Jake Gruber's m
Similar to Jake Gruber's message only on a rebuilt 318.
The engine was apparently rebuilt about 10 years ago and sat for that long before I put it back together this winter and just now - this week - fired it up in the moisture missle.
I am getting gargantuan blow by to the point that it's coming out the exhaust and when the engine shuts down it smokes for a good 15-20 minutes.
Cold compression tests tell me I only have 90 all the way along one bank and 100 all the way along the other bank.
Could the rings be sitting tight - perhaps seized - on the pistons?
Is this situation likely to improve with a few hours of running as the rings get lubed and hot?
Anyone with any experience with this problem in a "new" rebuild?
Mark
"I had an experience one time,
"I had an experience one time, where the rings were put in upside down. Lots of blow by.
I would think that it would be a stretch to have ALL the rings seized."
"It's possible if it sat t
"It's possible if it sat that long. Pull the plugs and squirt LOTS of kerosene into each cylinder. Wheel it over and squirt it again, then let it sit for a few days. Replace the plugs, fire it up and run it at high idle for a while, blipping the throttle solidly now and then. With a little luck the rings will free up.
Jeff"
"And, then I forgot to post my
"And, then I forgot to post my previous to last message where I said thanks for the advice. I will have time to do that this week.
Mark"
