scooterkees
Dose the connector that plugs into the 30 hp engine have a seal or an oring?
Scooter
Scooter
no gas leak. when i first got my motor the primer bulb would get realy hard . now no matter how hard pump the bulb stay soft. this is the second bulb and it seem to have the same promblem. i have replaced both fuel filters and the hose. the motor wants to stall under power then stops then wait and it starts agin. the water pump is pushing a lot of water so i dont think its the problem. it seem the motor is straining for fuel. cleaned out tank and only use non ethonal gas. plus use startron. so i belive it is pulling air from some where and that connector looked bad.Hi,
Are you experiencing a fuel leak? Here's a link that explains how the quick connection works. Often a leak is simply because you didn't get the latch to lock on firmly.
Fuel Systems | Crowley Marine
In this section we will be discussing topics that include fuel system components, theory of operation, and maintenence procedures.www.crowleymarine.com
This has a good picture of the oring.
Good luck
Boy!!! You guys are really smart.Every thing y’all suggested makes real good sense. However right now I’m under the weather.This could be a symptom of the tank air vent being closed or plugged up. Try running it with the fill cap loose or off (careful!) to see if the condition improves.
If not, then make sure that the tank pickup tube is in good shape and not snapped off and sucking air inside the tank.
If all that looks ok then
Alan makes a good suggestion. It makes good sense for this plus he works on the three cylinder carb models a lot. I don't.
Just want to offer you this though.
Honda Outboard 30HP OEM Parts Diagram for Carburetor Tubing | Boats.net
Buy OEM Parts for Honda Outboard 30HP Carburetor Tubing Diagramwww.boats.net
Items 19,6 and 20 in the link are the fuel feed lines from the pump to the carb inlet nipples.
You might try blocking them off, one at a time, to see if the bulb firms up. Since I've never tried this I don't know how access is or how much of a pain it would be. It's just an idea of how to find out if one or all of the carb floats might be stuck and flooding.
One other thing that might cause this, even though fairly unlikely, is that the seal inside the fuel pump is leaking and gas is escaping inside the valve cover.
If you do find the pump or the carbs are the cause, keep in mind that the engine oil will now be contaminated with ergasoline so an oil and filter change should be done immediately.
Good luck and please keep updating.
